Colocado por: callinasÉ interessante. Não deve ser barato.
Colocado por: Anonimo16062021Existe ainda este ..240 x 599 x 249.,(3,61 €)
Condutividade térmica de lambda = 0,10
Coeficiente de transferência de calor U = 0,39
//=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.g.height&&c<=b.g.width)}a&&(b.a.push(e),b.c[e]=!0)}p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});function r(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.i&&(e="&rd="+encodeURIComponent(JSON.stringify(t())),131072>=a.length+e.length&&(a+=e),d=!0);u=a;if(d){c=b.h;b=b.j;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(v){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}}function t(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("data-pagespeed-url-hash");e&&(!(e in b)&&0=b[e].o&&a.height>=b[e].m)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b}var u="";h("pagespeed.CriticalImages.getBeaconData",function(){return u});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/42996/bloco-termico-paredes-exteriores-com-eps-integrado/','eMkCkvev5V',true,false,'w86IIuur0Zg'); //]]>
Qual a razão de ter comparado com o capoto de 10cm? Esse Extrabloco tem 10cm de EPS acoplado?Boa tarde.
Colocado por: doct7Boa tarde.
Pelo que sei o regulamento da térmica exige um U=<0.3 na zona de Nelas onde vivo. Estudei que para paredes exteriores o bloco térmico de 30cm e o capoto de 10cm cumprem o regulamento das zonas climáticas I3. O ExtraBloco tem isolamento de 8cm de neoplas segundo diz no site.
Ainda não terminei o curso de engenharia, mas já vou sabendo algumas coisas.
Os sinceros cumprimentos.
Eu não consegui ver essa informação por isso é que perguntei.
Já agora consegue-me enviar o link dessa mesma informação?
Esse tipo de blocos são uma solução, como muitas outras, umas até sem qualquer tipo de isolamento, como é o caso do Bloco Megatérmico por exemplo.
Não esquecer que os tais supostos "35€/m2" para capoto de 10cm, deixam a parede exterior totalmente terminada.
Com estes blocos terá de acrescentar o "chapisco", e o reboco, bem como a pintura.
Não sei se nessa solução existe a necessidade de se colocar um barramento armado na zonas dos pilares e vigas que é onde leva a forra térmica. Em todas as soluções que vi deste género, essa situação era necessária.
Colocado por: doct7
Esta é uma boa solução para a não utilização do capoto, visto este ser frágil e com o Extrabloco tem uma mini parede em betão exterior e com a vantagem de não ser necessária mão de obra especializada na execução do reboco, devendo a meu ver utilizar a rede não só nos pilares mas sim em todos os seus panos.
Outra vantagem é a colagem de painéis de de pedra.
Em suma é uma nova solução com as suas vantagens.
É sempre bom haver soluções, contudo é preciso haver um pouco de cuidado no que diz respeito a certas comparações que se possam fazer, e isto é para qualquer situação.
