  1. Colocado por: Arcade
    puxe lá pelos neurónios, gostava de ler o estudo.
    agora fiquei curioso .
    foi numa das minhas surfagens pela net
  2. Sérgio poderia ser este:
    https://www.degruyter.com/downloadpdf/j/aoter.2017.38.issue-1/aoter-2017-0004/aoter-2017-0004.pdf
    Li por alto mas a conclusão é que quanto menor a humidade maior o rendimento do equipamento.
  3. Colocado por: pedromlopesSérgio poderia ser este:
    não era isso
  4. Já descobriu o estudo da formaçao de toxinas a diferentes temperaturas de combustão?
  5. Can Firewood Be Too Dry?
    Yes, although it is not a common problem
    Properly seasoned firewood still has a fair amount of water in it, say 15 to 20 percent of its weight. That water regulates the combustion process along with a few other factors like piece size, load configuration and combustion air supply.
    The higher the fuel moisture, the slower the wood breaks down when heated because of all the heat energy soaked up in boiling the water out of the wood and raising the temperature of the steam.
    Conversely, the dryer the wood, the more quickly it breaks down when heated. By breaking down, I mean the vaporization of the volatile components of the wood; that is to say, it smokes. The dryer the wood, the more dense is the smoke at a given heat input rate.
    Since wood smoke is fuel, we want to burn it as completely as possible and that means mixing with adequate oxygen in the combustion air. The problem is that a firebox load of very dry wood produces far more smoke than the air supplies of stoves are designed to provide. Besides, even if you could supply enough air, you would produce an inferno that would howl in the stove and make everyone in the house nervous. Fires that intense can seriously damage the stove's innards. Wood that is very dry produces a fire that is hard to control without making a lot of smoke.
    Kiln-dried wood is down around 10 percent moisture. Depending on climate and conditions of storage, normal firewood won't dry down to kiln-dried moisture because of normal outdoor humidity. For example, I've never measured wood below about 14 percent in my firewood supply. But I suppose that firewood could get very dry by natural seasoning in desert conditions. Or firewood stored in old barns, which are like kilns in hot summer weather.
    The right band of firewood moisture is between 15 and 20%. When you get much over 20% you start to see symptoms of sluggish ignition and the inability to turn down the air without extinguishing the flames. Towards 30% the wood sizzles and fires are very sluggish and it is hard to get a clean burn until the wood is almost to the charcoal stage. Above 30% water bubbles from the end grain when the wood is heated and it is very hard to burn at all. Species like poplar/aspen, which have very high native moisture content are virtually non-combustible when not adequately seasoned.
    The main difference between EPA low-emission certified stoves and conventional stoves is that you can turn down EPA stoves for a long burn without extinguishing the flames. That is, they are better at producing a clean, controlled fire. The EPA test method requires wood with a moisture content between 16 and 20 per cent (19 - 25% dry basis) and when the wood is outside this moisture band, the stove's emission rate goes up. So even the best wood stove's performance will suffer if the wood is not in the right moisture range.
    If you have some very dry firewood, like kiln-dried cut offs or old wood stored in a hot place, mix it with regular firewood to raise the moisture content of a full load.
    https://woodheat.org/firewood-too-dry.html
    Estas pessoas agradeceram este comentário: pedromlopes
  6. nao era isso ainda, era mesmo um estudo em que se focavam nisso, foi num daqueles dias em que um link levava a outro link e no fim encontrei isso
  7. .
  8. .
  9. .
  10. .
  11. #1928, isso tem arranque automático?
    É lareira para para quantos kil€s?
  12. Colocado por: Marcopom#1928, isso tem arranque automático?
    uns milharezitos =) ficava bem na sua casa
  13. Naaa, então p€sa muito a lage não aguenta, ainda me cai ao desvão sanitário...
  14. Mas que era uma lareira dessas, era 😍..
  15. Colocado por: MarcopomNaaa, então p€sa muito a lage não aguenta, ainda me cai ao desvão sanitário...
    mete uns barrotes por baixo
  16. Colocado por: Sergio Rodriguesmete uns barrotes por baixo
    Os barrotes são para meter dentro arder..
  17. ate nem é muitooooooooooo caro, é carito bah!!!
  18. Isso dá praí quase um milhar de bombonas de propano...
    Concordam com este comentário: Sergio Rodrigues, eu
  19. Boas noites.
    Eu estou a pensar instalar uma caldeira de chama invertida da Ladan 25kw. Já pesquisei mas não encontro mais informação do que aquela que têm o site. Eu queria feedback de alguém que tenha uma maquina destas, se é verdade a grande autonomia anunciada. OU conselho para uma outra Caldeira de chama invertida.
0.0709 seg. NEW
