    Colocado por: two-rokTambém serve para o PVC das caixilharias? Vou já chatear a CMartin. :P
    Olhe que estou atenta :oP
  2.  # 402
    Colocado por: Skinkx"vinyl chloride (an ingredient of PVC) has been found to be carcinogenic. After that was discovered, regulations limited the amounts of vinyl chloride allowed in PVC water pipes. However, EPA-allowed amounts still exist. The greater concern is in the solvents used to glue the joints and in the metallic components used to guard the piping from heat degradation."
    https://www.kudzu.com/article/PVC-Pipes-Are-They-Safe-for-Drinking-Water-id10001493
    Skinkx,
    "Polyvinyl Chloride
    Economical, versatile polyvinyl chloride (PVC, or vinyl) is used in a variety of applications in the building and construction, health care, electronics, automobile and other sectors, in products ranging from piping and siding, blood bags and tubing, to wire and cable insulation, windshield system components and more.
    Uses & Benefits
    Vinyl is versatile: it can be as rigid as industrial pipes, as pliable as plastic wrap, and as thin and flexible as wallcovering. It can also be completely clear or matched to any color desired.
    Building and Construction
    About three-quarters of all vinyl produced goes into long-lasting building and construction applications. Life-cycle studies show PVC/vinyl is effective in protecting the environment, in terms of low greenhouse gas emissions and conservation of resources and energy.
    Because it is strong and resistant to moisture and abrasion, vinyl is ideal for cladding, windows, roofing, fencing, decking, wallcoverings, and flooring. Vinyl does not corrode like some building materials, does not require frequent painting and can be cleaned with mild cleaning products.
    Siding and Windows
    Vinyl helps produce siding and window frames that are extremely durable, affordable, and help conserve energy when heating and cooling homes. In fact, vinyl windows have three times the heat insulation of aluminum windows.
    Wiring and Cables
    Vinyl is able to withstand tough conditions behind building walls – such as exposure to changing temperatures and dampness – for the life of the building. As a result, it is one of the most prevalent and trusted materials used in electrical wiring and cables.
    Water Pipes
    PVC helps conserve energy and water by creating virtually leak-free pipes that are not prone to corrosion and resist environmental stress. PVC breakage rates are as low as one percent of the breakage rates of cast metal systems. The lack of build-up in PVC piping improves functionality and increases energy efficiency.
    Packaging
    Because it is durable, dependable and light weight, flexible PVC helps packaging do its job to maintain the integrity of the products inside, including medicines. Clear vinyl is used in tamper-resistant over-the-counter medications and shrinkwrap for consumer products. Rigid vinyl film is used in blister and clamshell packaging to protect medicines, personal care products and other household goods.
    Healthcare
    Vinyl plays a critical safety role in dispensing life-saving medicine through IV bags and medical tubing. The advent of the PVC blood-collection bag was a significant breakthrough because blood bags are flexible and unbreakable, enhancing the development of ambulatory medicine and serving as the foundation for modern blood banks.
    Household Products
    PVC’s affordability, durability and water resistance make it ideal for rain coats, boots and shower curtains.
    Safety Information
    Many vinyl products are certified to meet special requirements set by regulatory authorities or other standards. PVC pipe for delivering drinking water must be certified by NSF International to conform to U.S. Environmental Protection Agency (EPA) safety regulations. Medical and food-contact products must meet U.S. Food and Drug Administration regulations.
    While some new vinyl products have an odor, the small amount of volatile organic compounds (VOCs) emitted will dissipate quickly through normal ventilation – in fact, tests have shown that the initial odor of vinyl wall coverings dissipates much faster than odors from most paints. Vinyl products are able to meet low VOC requirements in standards such as FloorScore®, Green Label Plus and GREENGUARD.
    Vinyl is manufactured by polymerizing (linking together) a chemical called vinyl chloride. Regulations strictly limit levels of vinyl chloride in the workplace and in emissions from manufacturing plants. Manufacturers convert as much vinyl chloride into PVC as possible to make maximum use of this raw material, then apply steam to strip out the remaining vinyl chloride so that levels in the finished vinyl are negligible.
    Tested, Effective, Affordable
    Vinyl is largely derived from salt — an abundant and inexpensive resource – and ethylene, which is derived from natural gas. Vinyl products consume less energy, generate fewer emissions, and save more energy than many other products.
    PVC is used in the production of hundreds of products that consumers encounter in everyday life, and many more that are encountered less frequently but are nevertheless important in construction, electronics, healthcare and other applications. PVC is used in these applications because of its low cost and desirable physical and mechanical properties. It is fabricated efficiently into a wide range of both rigid and flexible products. PVC also has inherent flame resistance. Substitutes for PVC materials may be available, but often the alternative materials and processes are not as efficient or substitution costs are high.
    Answering Questions
    Is PVC a major source of dioxin?
    Dioxin comes from many sources, according to EPA. PVC is an extremely small source, so small that levels of dioxin in the environment would be essentially unchanged even if vinyl were not being manufactured and used every day in important products. Overall dioxin levels in the environment have decreased by more than 90 percent since 1987, during which time production and use of vinyl have more than tripled.
    Are phthalate plasticizers safe?
    Phthalate plasticizers are added to vinyl when flexible products are being made. Phthalates have been thoroughly studied and reviewed by a number of government scientific agencies and regulatory bodies world-wide and these agencies have concluded that phthalates used in commercial products do not pose a risk to human health at typical exposure levels. Information collected by the Centers for Disease Control and Prevention over the last 10 years indicates that, despite the fact that phthalates are used in many products, exposure is extremely low – significantly lower than any levels of concern set by regulatory agencies.
    What about heavy metals?
    Stabilizers are added to vinyl formulations to lubricate and control the integrity of the material in the manufacturing process, or for coloring. These additives are usually based on compounds of tin, calcium, barium and/or zinc. They are held tightly in the material. In the United States, lead and cadmium have been almost entirely phased out of vinyl consumer products.
    Fonte : www.chemicalsafetyfacts.org/polyvinyl-chloride/
    About this Website
    The purpose of ChemicalSafetyFacts.org is to provide consumer-friendly information about some of the chemicals that are essential to the products that people use every day.
    This website is intended to provide general information only about various chemistries, their uses and function; it does not and cannot provide safety information specific to any particular consumer product or chemical, it is not intended to be comprehensive or complete, and should not be relied upon to ensure safe and appropriate use of any particular product or chemical.
    Because the safety of any consumer product requires an understanding of its specific chemical composition, as well as the intended uses of the product and potential exposure to various constituents, consumers should follow the specific instructions and product labeling provided by the product manufacturer, and seek safety information specific to that product from the product manufacturer.
    If you are looking for information about a chemical that is not on this site, let us know. We will be updating the site and adding information about more chemicals on a regular basis.
    Please let us know if you have any questions about the information contained on this website.
    This site is developed and maintained by the American Chemistry Council.
  3.  # 403
    Estão a quantificar a exposição a ftalatos e metais pesados quando deveriam dizer que outros plásticos nem sequer têm presenças desses produtos.
    Nem sequer chega a ser uma discussão.
  4.  # 404
    Boa noite . Já pensaram em proteger a vossa habitação? O seguro morreu de velho.
  5.  # 405
    São os primeiros a sofrer infelizmente.
  6.  # 406
    Eu vou por prossegur!!
  7.  # 407
    Colocado por: CMartinOlhe que estou atenta :oP
    É que não duvido nada mesmo. :P
    Mas é como o Skinkx já explicou atrás. Não sendo para estar em contacto com água potável e coisas do género, o perigo será bem menor.
    • hsi
    • 17 outubro 2018 editado
     # 408
    Colocado por: Anonimo06082021resultados da pesquisa já há?
    Bom dia,
    Nim ;)
    Estive a ler muito acerca de materiais, vantagens e desvantagens (note-se de quem lê e não tem experiência na sua aplicação prática) e percebo que há muitas soluções "melhores" do que a que me estão a propor em projecto. Entendo que a minha solução será, dentro das tradicionais (materiais) a melhor, mas não deixa de haver materiais bem melhores.... claro que também mais caros. Agora resta saber quanto mais caro ficaria a solução com outros materiais.
    A sensação com que fico é que com quem falo têm experiência em PEAD e PPR. Do resto pouco ou nada e isso deixa-me desconfortável.
    Não sei se devia falar me marcas mas do que vi gostei das soluções (por exemplo) da Rehau, Geberit, Uponor, GF, etc.
    No exterior está Previsto PEAD e, errado ou não, aí parace-me a coisa clara. Daí para a frente é que fico com dúvidas. PPR e PEX-a?? Inox e PEX-a/MC?? e depois também os €€€. Tenho que ver.
    Como disse, uma coisa que deveria ser simples já me pôs a pensar no futuro. É como tudo, quanto mais leio pior fico.
  8.  # 409
    Colocado por: hsiEstive a ler muito acerca de materiais, vantagens e desvantagens (note-se de quem lê e não tem experiência na sua aplicação prática) e percebo que há muitas soluções "melhores" do que a que me estão a propor em projecto. Entendo que a minha solução será, dentro das tradicionais (materiais) a melhor, mas não deixa de haver materiais bem melhores.... claro que também mais caros. Agora resta saber quanto mais caro ficaria a solução com outros materiais.
    No exterior está Previsto PEAD e, errado ou não aí parace-me a coisa clara. Daí para a frente é que fico com dúvidas. PPR e PEX-a?? Inox e PEX-a/MC?? e depois também os €€€. Tenho que ver.
    Não vale a pena gastar dinheiro em materiais de topo, se depois o instalador não os souber aplicar.
    Escolha o instalador, e depois aplique o material com que ele se sente mais confortável a trabalhar.
    Concordam com este comentário: hsi, zedasilva, two-rok, MRK
    • hsi
    • 17 outubro 2018
     # 410
    Obrigado e de acordo. Por isso escrevi.
    Colocado por: PicaretaA sensação com que fico é que com quem falo têm experiência em PEAD e PPR. Do resto pouco ou nada e isso deixa-me desconfortável.
  9.  # 411
    há quem ande de ferrari em troços de rally.
  10.  # 412
    Concordam com este comentário:hsi,****,zedasilva
    São tubos, nos esgotos é quase tudo macho-fêmea e nas águas há poucos ou nenhuns segredos.
    Qualquer canalizador lhe faz uma instalação em multicamada ou inox cravado e esgotos em PP. Só mesmo o PE soldado dos esgotos é que é pouco usado por cá e requer técnicas e máquinas pouco usuais, o resto qualquer profissional deveria ter capacidade para executar... a partir daí, a qualidade dos tubos e acessórios fica à medida da carteira de quem paga.
    Concordam com este comentário: Ivo F., tmmc
    Estas pessoas agradeceram este comentário: hsi
  11.  # 413
    Bond, porque é que optou por esse depósito? Devido à largura das portas?
  12.  # 414
    Concordam com este comentário:Ivo F.
    Já mudou um bocadinho a opinião que tinha antes, de a maioria não saber trabalhar com esses materiais, assim já concordo consigo.
    • Ivo F.
     # 415
    Colocado por: ****
    Disse bem DEVERIAM , mas acredite que,em Portugal não existem assim tantos a fazer fora do habitual !!
    O que parece complicado as vezes não é, o problema não é a falta de conhecimentos, aposto mais na falta de brio, quem trabalha bem acredite que não é esse tipo de tubos que mete medo. Agora pra quem trabalhe mal, pode sair cagada, mas sai cagada com esses, com ppr e com pex... Não depende do material
  13.  # 416
    Colocado por: Ivo F.
    Trabalhar com a precisão do Bond a maioria não sabe, nem que queira. Mas fazer uma instalação em multicamada (águas) ou em PP (esgotos) todos deviam saber.
    Em boa verdade, todos os dias vejo aberrações em PEX e PPR, por isso não é lícito que todos saibam fazer o básico, porque é um sector onde se apanha de tudo.
  14.  # 417
    Eu não diria que não sabem mas eventualmente que não querem.
    Trabalhar com a precisão do Bond custa dinheiro. Isso não está ao alcance de qualquer um. Seja DO seja profissional
    Concordam com este comentário: two-rok, rmarinho84
  15.  # 418
    Colocado por: zedasilva
    Acredite que não sabem. A maioria não sabe, nem que os ensine, nem que os mande para a escola. E depois há muitos que gostavam de saber, mas como adjudicam sempre ao mais barato lá têm que andar no campeonato da concorrência e das marcas brancas. Mas há muitos que não sabem, que nem sequer percebem o funcionamento teórico de algumas coisas.
    Há muitos que até podiam aprender a fazer mais e melhor, mas também não há muito quem ensine nem muito onde se possa fazer formação contínua. Ao contrário da electricidade, ITED, energia (solar, biomassa, bombas de calor, caldeiras), não há actualização nem formação contínua para canalizadores, são o "parente pobre" da construção. E isso reflecte-se na própria carreira profissional.
  16.  # 419
    Não estou a dizer que são todos assim, mas aqui em Portugal deve andar nos 50/50. Daquilo que apanho em obra, a qualidade do trabalho que vejo está um nojo ainda antes de se começar a analisar a qualidade do material. E quem trabalha assim tanto faz ser material Geberit como chinoquice.
  17.  # 420
    Colocado por: SkinkxHá muitos que até podiam aprender a fazer mais e melhor, mas também não há muito quem ensine nem muito onde se possa fazer formação contínua.
    Esta é uma grande verdade!
    Depois tb não há muitos clientes e técnicos a exigir qualidade. Como aquilo é para ficar tapado, desde que não fique a mi jar já está bom.
0.0302 seg. NEW
