Compressed Air Energy Storage (CAES)
Compared to chemical batteries, micro-CAES systems have some interesting advantages. Most importantly, a distributed network of compressed air energy storage systems would be much more sustainable and environmentally friendly. Over their lifetimes, chemical batteries store only two to ten times the energy needed to manufacture them. [4] Small-scale CAES systems do much better than that, mainly because of their much longer lifespan.
Furthermore, they do not require rare or toxic materials, and the hardware is easily recyclable. In addition, decentralised compressed air energy storage doesn’t need high-tech production lines and can be manufactured, installed and maintained by local business, unlike an energy storage system based on chemical batteries. Finally, micro-CAES has no self-discharge, is tolerant of a wider range of environments, and promises to be cheaper than chemical batteries. [5]
Although the initial investment cost is estimated to be higher than that of a battery system (around $10,000 for a typical residential set-up), and although above-ground storage increases the costs in comparison to underground storage (the storage vessel is good for roughly half of the investment cost), a compressed air energy storage system offers an almost infinite number of charge and discharge cycles. Batteries, on the other hand, need to be replaced every few years, which makes them more expensive in the long run. [5,6]
To give an idea of what a combination of the right components can achieve, let’s have a look at a last research project. [27] It concerns a system that is based on a highly efficient, custom-made compressor/expander, which is directly coupled to a DC motor/generator. Apart from its efficient components, this CAES project also introduces an innovative system configuration. It doesn’t use one large air storage tank, but several smaller ones, which are interconnected and computer-controlled.
The setup consists of the compression/expansion unit coupled to three small (7L) cylinders, previously used as air extinguishers, and operates at low pressure (max 5 bar). The storage vessels are connected via PVC pipework and brass fittings. To control the air-flow, three computer-controlled air valves are installed at the inlet of each cylinder. The system can be extended by adding more pressure vessels.
