    Colocado por: ****Eu em África vi muitos a construir em briques como os hebreus, amassam a terra com palha, outros aplicam terram sobre uma estrutura em Ramos
    E de vez em quando lá vinha uma abaixo e ficava uma família inteira debaixo dos escombros.
    Um poema:
    Prejudices against earth as a building material
    Owing to ignorance, prejudices against
    loam are still widespread. Many people
    have difficulty conceiving that a natural
    building material such as earth need not be
    processed and that, in many cases, the
    excavation for foundations provides a material
    that can be used directly in building.
    The following reaction by a mason who had
    to build an adobe wall is characteristic:
    ”This is like medieval times; now we have
    to dirty our hands with all this mud.” The
    same mason, happily showing his hands
    after working with adobes for a week, said,
    ”Have you ever seen such smooth mason’s
    hands? The adobes are a lot of fun to
    handle as there are no sharp corners.”
    The anxiety that mice or insects might live in
    earth walls is unfounded when these are
    solid. Insects can survive only provided there
    are gaps, as in “wattle-and-daub” walls. In
    South America, the Chagas disease, which
    leads to blindness, comes from insects that
    live in wattle-and-daub walls. Gaps can be
    avoided by constructing walls of rammed
    earth or mud bricks with totally filled mud
    mortar joints. Moreover, if the earth contains
    too many organic additives, as in the case of
    lightweight straw clay, with a density of less
    than 600 kg/m3, small insects such as wood
    lice can live in the straw and attack it.
    Common perceptions that loam surfaces are
    difficult to clean (especially in kitchens and
    bathrooms) can be dealt with by painting
    them with casein, lime-casein, linseed oil
    or other coatings, which makes them nonabrasive.
    As explained on p. 132, bathrooms
    with earth walls are more hygienic than
    those with glazed tiles, since earth absorbs
    high humidity quickly, thereby inhibiting fungus
    growth.
    Gernot Minke - Building with earth_design and technology of a sustainable architecture
    Recuperador de calor Egípcio feito em terra (adaptado do Austríaco Kachelofen)
    Hassan Fathy
    Existem obras contemporaneas em taipa e são interessantes.
    Colocado por: ****
    Never !!
    Não conheço muito de África, mas dos 2 anos que lá vivi, aconteceu várias vezes.
    Além das intempéries há também o problema das formigas que atacam a madeira.
    E depois há os padrões europeus, australianos ou norte americanos de construção em terra...
    Mas já vão aparecendo curiosos exemplos de África
    https://www.dezeen.com/2014/01/14/childrens-library-muyinga-africa-rammed-earth-walls-bc-architects/
    • tnjp
    • 30 janeiro 2019
     # 28
    Pesquisem pelas Casas de Salão do Porto Santo. Casas tradicionais com telhados em terra ("salão"). Já existem poucas em condições.
  8.  # 29
    Colocado por: rjmsilva
    isso é preconceito... fique a saber que algumas das construções mais antigas ainda existentes são em terra.
    Estas pessoas agradeceram este comentário: Daniel F Duarte
  9.  # 30
    Não é preconceito, é a realidade. Vivi dois anos em África e sei do que falo.
  10.  # 31
    Colocado por: rjmsilvaNão é preconceito, é a realidade. Vivi dois anos em África e sei do que falo.
    é preconceito sim, eu posso dizer o mesmo que si da construção em tijolo e cimento... ''E de vez em quando lá vinha uma abaixo e ficava uma família inteira debaixo dos escombros.'' vivi dois anos no Brasil e sei do que falo... aliás dá para dizer que qq sistema construtivo. os maus exemplos não são o exemplo pois constoi-se mal em todos os sistemas construtivos. agora, existem edificações em terra com séculos de existência.
    Concordam com este comentário: Pedro Barradas, desofiapedro
  11.  # 32
  12.  # 33
  13.  # 34
  14.  # 35
    Morton et al (2005) Low Cost Earth Brick Construction
  15.  # 36
  16.  # 37
    Estas pessoas agradeceram este comentário: branco.valter, zinna
  17.  # 38
    Impressão 3D com terra
    https://iaac.net/project/digital-adobe/
    https://www.3dwasp.com/en/3d-printing-architecture/
    e já agora um pouco de arroz:
    https://www.ricehouse.it/
  18.  # 39
    Muito interessante!
    https://www.youtube.com/watch?v=KPaOCWrZJ94
    Vou enviar o video a uns quantos conhecidos, obrigado José.
    Estas pessoas agradeceram este comentário: José Barnabé
  19.  # 40
    Faça isso sim, pode ser que consiga mudar uma cabeça ou duas. Há mais e melhor (muito melhor!!) além do betão e do tijolo! :)
    Concordam com este comentário: branco.valter
0.0246 seg. NEW
