    Parece-me bem...
    • zed
    • 23 julho 2019 editado
     # 522
    A Mirubee junta-se à Wibeee. Presumo que foi comprada pela Wibee/SMILICS pela sua tecnologia.
    Mirubee joins a new family
    Hello!
    ¡We have good news! Mirubee has been working for almost 8 years as a software company to improve energy efficiency in homes. In recent times we have worked very closely with the Wibeee company, manufacturer of our current measurement equipment. Finally, we believe that the time has come to definitely join forces to move forward with more drive than ever!
    This is why you will see soon that mirubee adopts the Wibeee brand in all its communications, as well as in the WEB and APP platforms. The mirubee platform will be renamed Wibeee Home.
    HOW DOES IT AFFECT ME?
    Your mirubee application will continue to work without any problems, but it will no longer be updated. We recommend you to install the new official "Wibeee Home" app. Don't worry, your historical data will still be there.
    WHAT IMPLICATIONS DOES IT HAVE FOR MIRUBEE?
    Mirubee will continue its commitment to service, but with the solidity of belonging to one big family. The hardware and software will now come out of the same house, from the same team. We hope that the project will grow faster and go further.
    WHAT ABOUT MY PERSONAL DATA?
    In order to continue providing the service, the company Wibeee (Smilics Technologies S.L.) will be responsible for processing the personal data of all customers of mirubee (Energy management system in the cloud S.L.).
    For questions related to the RGPD you can contact Wibeee through this address: [email protected]
  2.  # 523
    Já tinha conhecimento desta situação, para o consumidor, um dos aspetos menos bons é que o contador da Wibee é substancialmente mais caso do que o Mirubee.
  3.  # 524
    O mirubee não passa de um wibeee com software mais específico, mais elaborado.
    Não vale a pena vender dois produtos iguais mas com softwares diferentes.
    Fizeram bem.
    A aplicação Android do wibeee já é igual à do. mirubee mas em amarelo.
  4.  # 525
    Qualquer uma das aplicações tem um problema: o consumo "geral" mostra sempre positivo, mesmo quando é negativo, ao contrário do site que fica tudo direito.
    Claramente, o site é muito melhor que a app, por isso raramente a uso. O menu solar, o que uso mais, não tem nada a ver...
    O site da wibeee é amarelo, e perdeu a cor vermelha das setas quando está a haver injeção na rede, o que permitia mais rapidamente identificar esta situação.
    • zed
    • 28 julho 2019 editado
     # 526
    Colocado por: bbaixoJá tinha conhecimento desta situação, para o consumidor, um dos aspetos menos bons é que o contador da Wibee é substancialmente mais caso do que o Mirubee.
    O Wibee Box está agora a um preço ligeiramente inferior ao que paguei pelo Mirubox há uns meses. Será que eles alinharam os preços pelos da Mirubee?
    Edit: afinal são preços sem IVA.
    https://wibeee.com/wibeee-home-shop/
  5.  # 527
    Boas,
    Decidi avançar para o compra de um DataWatt para monitorizar o consumo geral da minha casa e do meu sistema Fotovoltaico.
    A instalação foi pacífica e por enquanto está tudo ok.
    Fica aqui o resultado.
    Estas pessoas agradeceram este comentário: skypt
  6.  # 528
    Colocado por: roberto_fBoas,
    Parece bem.
    Muito complicada a configuração? Monofásico ou trifásico?
  7.  # 529
    Colocado por: nuno_carlos44
    Parece bem.
    Tenho monofásico.
    É só colocar um sensor no cabo de energia que vai do quadro eléctrico até ao sistema FV.
    Depois é configurar esse sesor como "Produção" e na Cloud já aparece os gráfico de AutoConsumo.
  8.  # 530
    Eu tenho trifásico e um quadro "grandinho".
    Ainda nao tive paciência para colocar o Datawatt a funcionar.
    A "cena" das calibrações complica a coisa. É que com o trifásico ainda não percebi muito bem o que tenho de fazer.
    Acho que vai ter de ser num daqueles fds de inverno sem nada que fazer.
  9.  # 531
    Colocado por: Pedro Azevedo78Eu tenho trifásico e um quadro "grandinho".
    A Configuração parece complicada mas é simples em 15min fazes isso.
    Se tiveres dúvidas, podes sempre utilizar o contacto de suporte.
  10.  # 532
    Boas, já me chegou o DataWatt agora a ver se monto a coisa para depois deixar feedback
    Para já montado só fora para perceber as ligações
    Estou a pensar usar este carregador USB que vos parece
    PS - Ainda não entendi para que serve os fios azul e preto....
  11.  # 533
    Não tem uma caixa preta e um cabo USB?
    Liga o USB à caixa preta e liga os fios azul e preto à caixa e ao quadro elétrico.
    Estas pessoas agradeceram este comentário: brunozo
  12.  # 534
    Não tem caixa preta não :O será que era suposto?
    So tem mesmo o que tem aí na foto, os fios e um ligadores :O
    Esse transformador não veio, é de um telemovel que tinha para aqui....
  13.  # 535
    Mande email que devem-se ter esquecido do transformador.
  14.  # 536
    Colocado por: manelvcMande email que devem-se ter esquecido do transformador.
    Estas pessoas agradeceram este comentário:brunozo
    Resposta da DataWatt :) menos mal já estava a ver que não ia montar já o equipamento
    O carregador não faz parte do Kit.
    Pode usar um carregador normal de telemóvel que têm em casa
    • bbaixo
    • 3 setembro 2019 editado
     # 537
    Uns posts atrás, vejam como está ligado o meu DataWatt.
    Os dois cabos e os ligadores brancos servem para ligar o carregador que alimentará o DataWatt.
    É necessário ligar a outra extremidade dos cabos a um disjuntor e ao barramento de neutro.
  15.  # 538
    Colocado por: brunozo
    https://forumdacasa.com/?CommentID=1399064
    Só se não fizer agora....
  16.  # 539
    Bem estou aqui pendurado...
    Os sensores pelos vistos não estão a aparecer na cloud (o pessoal da datawatt deu esta informação) mas acho que estão OK...
    Alguém pode dar-me uma ajuda porque para além de terem levado quase 3/semanas para enviar o suporte pelos visto também está lento... (não sei se é por ser fim de semana)
    ligação geral
    Nesta vemos as pontas vermelhas nos orifícios logo os sensores estão bem ligados não
    sensores
    Na cloud aparece assim a informação
    cloud
    Alguém pode dar uma dica se faz favor...
  17.  # 540
    Confirme que o sensor está a fazer o contacto direitinho com o cabo. Como os cabo estão arredondados na curva pode ser mais difícil.
    Volte a fazer a configuração. Eu também não me aparecia um e voltando a fazer a configuração apareceu...
0.0424 seg. NEW
