Colocado por: PalhavaNo outro dia à saída do supermercado, uma jovem distribuía panfletos de um dentista em que ofereciam um check-up e limpeza...
10€!!!
Como é possível?
Colocado por: VCAC... Que não nos doam os dentes nos próximos dias...
Colocado por: civismoOpiniao interessante sobre limpeza do tartaro ... aconselham a que se faça manualmente, em vez ser por rotaçao / abrasão :
Our mistake number 1 is: letting our dentists use their turbine with their abrasives and ultra heat produced by the high spinning mini grinder to "clean" our teeth instead of hand scraping the tartar away...........This dentist process should be stopped because it first cuts the gum margin i.e. seal or connection of the gum to the teeth, this is why the bleeding at the dentist's "cleaning". This "cleaning" polishes the microscopic structure of the teeth margin that allows the gum to attach itself to the teeth. The dentist grinder/polisher's heat burns it killing this important live margin line between gum and teeth and the gum no longer can grip, hold or root itself onto anything from each tooth and recedes because now the tooth margin line is burnt/polished smooth.......If a similar cleaning was done onto the achilles tendon to bone one would not be able to stand ever. The ultra fast spinning and abrasive pastes and heat by your dentist is like having a regular tooth brush and dental paste going over the gum/tooth margin line millions of times in seconds and this is way more damaging than regular cold tooth brush cleaning. Such ignorant common practice by dentist is the main reason ........ Dentists ignorantly blame it on bad brushing....... Next time you visit your dentist you might want to sternly say what I say "no turbine cleaning on my teeth" or risk having your gums start receding
Colocado por: DR19821500€ por cada implante fixo é o valor normal?
Colocado por: DR1982Qual o seguro de saude que tem? Por acaso queria arranjar um realmente que valha a pena...
Colocado por: DiiiEu tambem tenho medis, ate
Tenho Medis e sei que comparticiparia também uma grande parte.... No entanto como também tenho SAMS, cobre mais uns €€ (em implantes).
Mas devo dizer que para todas as outras consultas normais de medicina dentária uso sempre a Medis pois é mais vantajoso que a SAMS.
Não tenho razão alguma de "queixa" da Medis... Uso e abuso! ;)
Colocado por: DR1982Eu tambem tenho medis, ate
Agora das que vi pareceu-me a mais vantajosa...
