Colocado por: omegaO Balão é de 12L e o termoacomulador é de 300L, é "alimentado" pelo painel solar e por uma resistência elétrica de apoio.como vai ter que colocar um novo opte por 14 litros, em principio a pré-carga de 4 bar é a correta.
a Agua em casa anda nos 3,5 a 4 bar (a agua vem de furo artesiano)
Devo aumentar o volume do balão ou o de 12L é suficiente?
Colocado por: jorgealvescomo vai ter que colocar um novo opte por 14 litros, em principio a pré-carga de 4 bar é a correta.
Reflex Reflex N 12
Diaphragm expansion tank for sealed heating and cooling water systems. Vessels fitted according to DIN EN 13831. Approval according to Pressure Equipment Directive 2014/68/EC.
Durable epoxy resin coating
Non-replaceable diaphragm according to DIN EN 13831
35 litres and above upright
For antifreeze additive of at least 25 – 50 %
With threaded connections
max. permissible system temperature 120 °C
Max. operating temperature 70 °C
Type: N 12
Colour: grey
Diaphragm material: SBR
Nominal volume: 12 l
Max. useful volume: 10.8 l
Max. permissible system temperature: 120 °C
Min. perm. operating temperature : -10 °C
Max. perm. operating temperature: 70 °C
Max. perm. operating pressure: 4 bar
Factory provided gas supply pressure: 1.5 bar
Connection: R 3/4"
Diameter: 272 mm
Height: 317 mm
Tilt dimension approx.: 418 mm
Weight: 2.75 kg
Refix DE
Non-flowed through diaphragm expansion tank for water supply installations that are not subject to DIN 1988, e.g. fire extinguishing and service water systems, underfloor heating or heat source installations. Vessels fitted according to DIN EN 13831. Approval according to Pressure Equipment Directive 2014/68/EC.
Bladder according to DIN EN 13831 / replaceable from 50 litres
Parts in contact with water are corrosion-protected
33 litres with brackets, from 50 litres with adjustable feets
following types incl. pressure gauge:
→ 10/16 bar: from Ø 1.000 mm
→ 25 bar: from Ø 450 mm
Pressure gauge and supply pressure valve protected by clip
Note:
No licence requirement according to SWKI HE301-01 and SVTI for (PSV * VN ≤ 3,000 bar * litre). Type: DE 18
Colour: blue
Diaphragm material: butyl
Nominal volume: 18 l
Max. useful volume: 13.5 l
Max. permissible system temperature: 70 °C
Max. perm. operating pressure: 10 bar
Factory provided gas supply pressure: 4 bar
Connection: G 3/4"
Diameter: 280 mm
Height: 407 mm
Tilt dimension approx.: 494 mm
Weight: 3.30 kg
Colocado por: omegapode
A loja tem disponível no imediato, 12 ou 18l. Posso colocar o de 18?
Colocado por: omegaPenso que deva colocar o da gama branca, certo? aceita temperaturas até 120 ºCtem k colocar o apropriado pada AQS
Reflex Reflex N 12
ou
Reflex Refix DE 18
