    • ze79
    • 27 março 2012
     # 641
    mosaico, atenção a espessura da talocha dentada ,o cimento cola não deve ficar no armazém ,respeitar as junta de dilatação.
    upss...
  1.  # 642
    lllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll
  2.  # 643
    lllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll
  3.  # 644
  4.  # 645
  5.  # 646
    Há muitas destas pedras assim, que não foi o que paguei, para mim, só serve para entulho....
    Dá quase para fazer uma palete e enviar para a pedreira de volta.... Enfim...
  6.  # 647
  7.  # 648
  8.  # 649
  9.  # 650
    Colocado por: nandogoncaDigam o que acham disto.
    nandogonca tente injectar calda de cimento( como já foi referido pelo Picareta) com equipamento(injecção por pressão de ar)que permita que a calda preencha todos os vazios sob a placa de xps.
    Não aplique o revestimento cerâmico sem resolver essa situação, porque no futuro terá que gastar dinheiro para partir e voltar a repor.
    Cumprimentos.
    Concordam com este comentário: ze79, two-rok
  10.  # 651
    Concordam com este comentário: C.CASTRO
  11.  # 652
    lllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll
  12.  # 653
  13.  # 654
  14.  # 655
    Colocado por: rui moreiranandogonca tente injectar calda de cimento
    Vou falar com o empreiteiro por causa disto. Entretanto nessa banda de dilatação, reparei que por baixo da estrutura da porta de correr, aquilo ficou vazio, será mais um local para encher e evitar estas movimentações. O empreiteiro tinha dado a opção de partir um pouco antes da banda de dilatação e encher essa parte outra vez, ligando-a com malhasol.
  15.  # 656
    é o chamado puzzle dos adultos!!!!
  16.  # 657
    Vou ver se resolvo isso. Os furos convem ser de 12mm ou superiores certos? e ao furar, o pó não irá impedir essa calda de entrar livremente?
  17.  # 658
    Colocado por: sergyioé o chamado puzzle dos adultos!!!!
    O quê?
  18.  # 659
    Colocado por: Anonimo16062021injetar a espuma de poliuretano nessas zonas onde as placas de isolamento estão mais soltas.
    À dias precisei de usar umas espumas dessas e não gostei do resultado final... Quais são as melhorzitas? E aquilo não dá para utilizar mais tarde, depois de usar a primeira vez? Como limpa o cano que fica sempre com espuma?
    PS: Maçarico que sou, não usei luvas e depois foi danado para limpar... No final descobri que a tampa da lata tinha lá umas luvas descartáveis...
  19.  # 660
    na foto # 782
    as peças espalhadas pela sala!!! :)
0.0369 seg. NEW
