  1. jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
  2. jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
  3. jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
  4. jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
  5. Colocado por: nandogoncajjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
    Para além do diferencial, mesmo num quadro parcial, gosto sempre de um interruptor de corte à entrada e pedi ao meu electricista para colocar os sinalizadores de tensão.
    cumps
  6. Colocado por: nandogoncajjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
    vamos a dar na cabeça do electrecista:
    -as marcas\cortes superficiais do alicate no isolamento eram escusadas, para evitar isso temos dedos!!
    -peça-lhe o esquema do quadro, porque creio que tem por ali alguns erros de palmatoria e que custam mais dinheiro a fazer mal do que a fazer bem.
    -pode ser da foto mas creio que tem por ali disjuntores de 16A a ligar circuitos de 1,5mm.
    -o quadro da cozinha ficou uma CAG**A com aqueles cortes laterais, e um único diferencial para tudo, (é chato que por causa da maquina de lavar fique sem frigorífico e arca congeladora, se estiver em casa ainda pode resolver, senão pode estragar tudo o que lá estiver)
    -a Certiel (e as RTIEBT idém)gosta que num parafuso SOMENTE seja ligado um único condutor, se o barramento é pequeno coloca outro maior, ou usa o superior que ainda por cima está vazio.
  7. Colocado por: nandogoncajjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
    do lado direito é um descarregador de sobretensão?
  8. Colocado por: electraodo lado direito é um descarregador de sobretensão?
    não, é o barramento do post 1233 com a tampa.
    Estas pessoas agradeceram este comentário: electrao
  9. Para a distribuição das fases, em quadros de iluminação e tomadas, não é costume usar um destes?
  10. Colocado por: electraoPara a distribuição das fases não costumam usar um destes?
    isso é para trifasico, o nando tem monofasico, por aí nem esta mal.
    Concordam com este comentário: electrao
  11. Colocado por: nandogoncajjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
    esses dois disjuntores bipolares estão a fazer a proteção aos quadros parciais? ou a alguma máquina?
  12. Colocado por: nandogoncaO material já cá está, à espera que alguém o monte.... Voluntários :-)
    é facil ate voçe o monta! sonnekraft tem isso de bom tanto a estrutura como as ligações no grupo hridraulico são bastantes simplificadas! vai ser voçe a meter ao sitio?
  13. Colocado por: electraoesses dois disjuntores bipolares
    acho que estes meninos estam muito mal,
    pois parece-me que têm calibres muito elevados para fazerem alguma coisa, o calibre de um corte a um quadro secundário deve no maximo ser dimensionado para a capacidade MAXIMA do cabo\condutor que o alimenta, daqui ter pedido o esquema do quadro.
  14. Colocado por: electraosinalizadores de tensão
    Que é isso???
  15. se deixar até Março por certo a malta antes de ir para o almoço do forumdabarraca dá-lhe uma mãozinha nisso.
  16. Colocado por: nandogoncaQue é isso??
    são "luzinhas" para saber quando tem tensão,
  17. Colocado por: jorgealvesse deixar até Março por certo a malta antes de ir para o almoço do forumdabarraca dá-lhe uma mãozinha nisso.
    hihihihihi ja estou a imaginar pôem o serginho a montar aquilo no telhado enquanto voçes enfardam uma birras!!!
    Concordam com este comentário: two-rok, jorgealves
  18. sinalizadores de tensão
  19. Colocado por: jorgealvespeça-lhe o esquema do quadro, porque creio que tem por ali alguns erros de palmatoria e que custam mais dinheiro a fazer mal do que a fazer bem.
    Acho que isso é coisa que não se utiliza por cá... Pelo menos não vi nada disso...
    Que erros??
    Colocado por: jorgealvespode ser da foto mas creio que tem por ali disjuntores de 16A a ligar circuitos de 1,5mm
    Isso tem a ver com o aquecimento que o cabo aguenta e os disjuntores de 16A, são para 2,5mm, certo??
    Colocado por: jorgealveso quadro da cozinha ficou uma CAG**A com aqueles cortes laterais, e um único diferencial para tudo, (é chato que por causa da maquina de lavar fique sem frigorífico e arca congeladora, se estiver em casa ainda pode resolver, senão pode estragar tudo o que lá estiver)
    Solução? Ele reclamava sempre do pouco espaço que tinha... Ao colocar outro diferencial teria que retirar disjuntores..
  20. Colocado por: nandogoncaAcho que isso é coisa que não se utiliza por cá
    fogo, é só fazer uns riscos num papel, não precisa de nada muito vistoso.
    Colocado por: nandogoncaIsso tem a ver com o aquecimento que o cabo aguenta e os disjuntores de 16A, são para 2,5mm, certo??
    teoricamente sim e também com as regras tecnicas que assim o obrigam.
    Colocado por: nandogoncaSolução? Ele reclamava sempre do pouco espaço que tinha... Ao colocar outro diferencial teria que retirar disjuntores
    simples, somente meter menos disjuntores, LOL
0.0395 seg. NEW
