    nesta não...
    é em aço inoxidável
  2.  # 202
    e a câmara de combustão é em betão.
  3.  # 203
    Para não ter uma temp. de Retorno na Caldeira inferior a 50/55º,usar uma Válvula termoreguladora, evitando a condensação da mesma.
    - aplicar entre o Acumulador e a caldeira de gasificação
    • Arcade
    • 28 abril 2013 editado
     # 204
  4.  # 205
  5.  # 206
  6.  # 207
  7.  # 208
  8.  # 209
  9.  # 210
  10.  # 211
  11.  # 212
    Mais 1 loading unit da - lk armatur
  12.  # 213
  13.  # 214
  14.  # 215
  15.  # 216
    1-pump motor grundfos alpha 2l60
    2-lk 810 thermostatic element 55°c
    3-ball valve f 1"
    4-ball valve f 1¼"
    5-ball valve 28 mm
    6-gasket epdm 1½" - 44x27x2 mm
    7-thermometer 120°c, 51x7 mm, l60
    8-epp insulation lk 810
    9-element housing
    10-spring
    11-check valve lk 810
    12-plug lk 810
    • Arcade
     # 217
    Heating phase:
    The water circulates between boiler and loading unit while the temperature of the boiler is rising.
    • Arcade
     # 218
    Loading phase:
    The thermostatic element starts to open and allows return water from the storage tank to be mixed with supply water before it returns to the boiler. The return temperature to the boiler is kept constant.
    • Arcade
     # 219
    End phase:
    The thermostatic element is fully open and the flow from the bypass is closed. This results in an optimal transfer of heat from the boiler and the storage tank is filled with supply water.
    • Arcade
     # 220
    Self-circulation with check valve:
    Self-circulation will be obtained as soon as the fire has gone out and the circulating pump has stopped. The remaining hot water is loaded to the storage tank. In case of power failure or pump breakdown the check valve automatically opens to allow self-circulation. The check valve also stops recirculation from storage tank to boiler.
0.0647 seg. NEW
