    aonde se pode arranjar deste material aqui na zona setubal?
    estamos a pensar pior deste tipo de chao na suite, mas queria aproveitar para isolar e isto é otimo
  2.  # 362
    Wood Fiber Sound insulation and wood fiber insulation as cavity insulation for airborne and impact sound insulation of wood-beamed ceilings with suspended ceiling and poising
  3.  # 363
    insulation system from wood fiber insulation, jointing battens for board mounting and a dry bed to the improvement of impact sound insulation of solid ceilings
  4.  # 364
    Wood fiber sound insulation under dry screed elements to Improve the impact sound insulation of solid ceilings
  5.  # 365
    Laying of a fiber-reinforced gypsum screed element with factory under laminated wood fiber insulation board for the improvement of airborne and impact sound insulation of floors.
    • Arcade
    • 30 março 2014 editado
     # 366
    high pressure-resistant wood fiber insulation boards under floating engineered wood sill plates for heat insulation of houses without floor panels.
  6.  # 367
  7.  # 368
    wood fiber insulation as a thermal insulation attic floor with walk-cover made ​​of wood-based panels
  8.  # 369
    ... para mais info ver em :
    http://www.holzfaser.org
  9.  # 370
    Colocado por: Zegatoaonde se pode arranjar deste material aqui na zona setubal?
    a rdz acho k tem disso
  10.  # 371
    Colocado por: Sergio Rodriguesrdz
    mas rdz é o que?
  11.  # 372
    rdz sistema radiante da caleffi acho k tem desse tipo d isolamento para radiante
  12.  # 373
  13.  # 374
  14.  # 375
  15.  # 376
  16.  # 377
  17.  # 378
  18.  # 379
  19.  # 380
0.0461 seg. NEW
