  2.  # 402
    Parkett
  3.  # 403
  4.  # 404
  5.  # 405
    Boa noite,
    estamos neste momento a aplicar 500m2 de soalho maciço num piso com aquecimento hidráulico. na realidade a experiencia diz-nos que o melhor é colar. E que o melhor é em vez de totalmente maciço, ter uma parte de contraplacado. assim tem um rendimento maior.
  6.  # 406
    Colocado por: fernando luisBoa noite,
    Colado não se esqueça das dilatações e das retraccões.
  7.  # 407
    teka
  8.  # 408
  9.  # 409
  10.  # 410
  11.  # 411
    • Arcade
    • 30 abril 2014 editado
     # 412
  12.  # 413
  13.  # 414
  14.  # 415
  15.  # 416
  16.  # 417
  17.  # 418
  18.  # 419
  19.  # 420
    Underfloor Heating Below Hardwood on Slab Plus Screed/Beam & Block Diagram
    Depending on the requirements of the hardwood, it may be necessary to fit battens to provide a fixing for wood flooring. This diagram shows how this can be done, by laying a framework of battens onto the insulation, after the underfloor heating pipes have been installed. The spaces between the battens must be infilled with a concrete mix to provide the thermal conductivity to the floor surface. A floor sensor can also be fitted into the screed to limit the floor temperature and protect the wood flooring, which is particularly useful for natural hardwood, but perhaps not necessary for engineered hardwood depending on the manufacturer's instructions.
    This technique is ideal for hardwood floors that need to be fixed into battens. After the underfloor heating pipes have been laid, floor battens are build in a framework onto the insulation. Alternatively, deeper battens can be laid onto the concrete first with insulation fitted between the battens and the underfloor heating pipes fitted onto the insulation. A concrete screed is poured around the pipes up to the top of the battens and the final floor is laid on top attached to the battens.
0.0454 seg. NEW
