    Colocado por: CMartinLudovino, o que falo da caleira em toda a volta da casa é isto, acho que se chama calha.
    //=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/41682/2/humidades-nas-casas/','B6nXayd9mu',true,false,'T3k5raFVqCo'); //]]>
    Mas veja o que dizem os profissionais porque eles saberão identificar o problema.
    Isso é grelha de escorrer água, caleira é nos telhados.
    Colocado por: Anonimo16062021
    Quanto eu sei na Suíça não se trabalha assim
    Anonimo16062021
    Sim na Suíça o xps vem logo acompanhar a construção abaixo do solo, mas o rodapé esta igual
    mas ja agora podia ser mais claro o que esta mal com aplicação do xps sfv.
    • joao2
    • 22 dezembro 2015 editado
     # 23
    Lodovino, nao tem caleira no telhado? Certo? Ás vezes os caleiros fazem milagres se conseguisse desviar a água da chuva para fora das paredes evitando os respingos do beiral quando chove.
    Estas pessoas agradeceram este comentário: Ludovino Machado
  3.  # 24
    Boa noite, Ja agora um obrigado a todos pela dicas,
    Sim e verdade o xps nao esta enterrada no solo mas como os quartos estão 20cm acima do solo,
    Achei que nao avia necessidade, E outra coisa entes de colar o xps foi impermeabilizado em forma de meia cana com WEBER DRY LASTIC
    Agora nao tenho aqui as fotos mas logo vou colocar no forum .
    Baa tarde João 2
    Sim tenho Caleiras
    Boa noite Sr.Anonimo16062021
    como pode ver na foto nos aplicamos um aimpermeabilizate em forma de meia cana de marca WEBER DRY LASTIC
    so depois colamos o XPS.E como os piso do quintal tem uns 20cm mais baixo achamos que nao avia problemas de humidades.
    cumprimentos
  6.  # 27
    Foto
  7.  # 28
    é aquilo escuro no recanto?
  8.  # 29
    Bom dia
    O material espuro é Weber Dry Lastic
  9.  # 30
    Bom dia Sr Dias Borge
    Como o senhor diz que a impermeabilização nao está bem feita ,mesmo tendo em conta que a habitação esta mais alta uns 20cm que o solo.
    E ja agora qual a melhor solução.
    Cumprimento
    • smar
    • 23 dezembro 2015
     # 31
    Bom dia,
    É um tema que me interessa, vou também aplicar capoto, e no meu caso o piso está ao nível da rua!
    Caro Dias, onde podemos comprar essa espuma comprimida para meter nas caixilharias(que irão ser também substituídas) ?
  10.  # 32
    Colocado por: Ludovino MachadoA forma do rodapé no exterior esta como se faz na Suíça
    O que não falta na Suiça é quem tem a mania que sabe trabalhar, o problema é que depois lixam-se porque as coisas são um pouco diferentes que em Portugal.
  11.  # 33
    A empresa que fez o trabalho de capoto na minha casa,o responsável tem mais de 20 anos de Suica a fazer trabalhos de capoto ,E em Portugal mais uns quantos.
    • 23 dezembro 2015
     # 34
    Colocado por: Ludovino Machadocomo pode ver na foto nos aplicamos um aimpermeabilizate em forma de meia cana de marca WEBER DRY LASTIC
    Provavelmente a água que cai no terraço está a passar por baixo dessa zona.
  12.  # 35
    boas pelas fotos que colocou da me a impressão que esse problema ja existia antes ,por a pintura estar a descascar dessa forma
    se nao tratou isso bem ,a impermeablizacao que deu nao e suficiente nao vai ser fácil de resolver .
    ha minha opinião vale o que vale nao entendo muito de obras.
0.0206 seg. NEW
