    Colocado por: Anonimo16062021.//=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/40018/16/diario-da-construcao-da-minha-vivenda/','B6nXayd9mu',true,false,'-fP4GcVVPhA'); //]]>
    http://i.imgur.com/IacuKl9.jpg
    http://i.imgur.com/vCkiVqH.jpg
    http://i.imgur.com/eAADAZc.jpg
    sim eu sei o que sao. mas onde e que se arranja isso em portugal, as eco tabs
    • VXMC
    • 10 janeiro 2016
     # 302
    O sr Dias tem mesmo jeito para a poda. Realmente sim senhor! Ja agora depois onde faz e como apoia o veio do estore? Tenho um empreiteiro que nao cede e continua a insistir que estas caixas sao melhores que as ja fabricadas. Nao sei o que escolher. O etics por fora depois remata nas suas caixas certo?
  2.  # 303
    Sr dias, qual a dimensao dessa caixa elaborada por si?
  3.  # 304
    Qual a espessura desse isolamento 25 cm?
    Estas pessoas agradeceram este comentário: tc82
  4.  # 305
    Essas que postei foram feitas na obra ca pelo velho
    pois mas que existe isso na alemanha ou na suiça ja eu sei
    alguem sabe se existe estas palas em portugal?
  5.  # 306
    Colocado por: tiago_ecoalguem sabe se existe estas palas em portugal?
    quando o Anonimo16062021 as fizer passam a existir.
    Concordam com este comentário: Schlüter-Portugal
  6.  # 307
    fazer eu tambem eu as faço.
    a questao é que juntar 2 ou mais placas de esferovite para fazer o comprimento pretendido da pala nao é a mesma coisa que comprar uma eco-tab que ja é devidamente reforçada para o efeito e com o comprimento desejado. (venha quem vier)
  7.  # 308
    ja tenho orçamento de electricista mas tá muito puxado.
    alguem conhece electricistas certificados na zona de aveiro?
  8.  # 309
    para actualizar a obra está concluida de pedreiro, passeios e muros.
    esta semana entreguei a electricidade e picheleiro
  9.  # 310
    orçamentaram me aluminio da alesil serie RT 60.
    as caracteristicas sao identicas a de outros sistemas com rotura termica. Só que aprensenta um coeficiente termico de 2,9 w / (m k) o que é quase o dobro do LT da SOsoares?! Vale alguma coisa? ou isto tem gato?lol
  10.  # 311
    Colocado por: tiago_ecoorçamentaram me aluminio da alesil serie RT 60.
    Tiago,
    Atenção que W/(m2K) mede o coeficiente de transmissão térmica de um material. Nas caixilharias, quanto maior o valor, pior são as prestações térmicas das caixilharias.
    Você tem de procurar ter o menor coeficiente de transmissão térmica, ou a maior resistência térmica possivel.
  11.  # 312
    Colocado por: santosvieira
    Tiago,
    sim eu sei disso. por isso é que referi que outros sistemas conseguem prestaçoes melhores
  12.  # 313
    Colocado por: arquitecturagaiaMeta fotografias da casa com a obra de pedreiro feita
    Estas pessoas agradeceram este comentário: arquitecturagaia
  13.  # 314
    1
  14.  # 315
    4
  15.  # 316
    5
  16.  # 317
    8
  17.  # 318
    85
  18.  # 319
    Tiago,
    A sua moradia vai levar isolamento no exterior?
  19.  # 320
    Colocado por: arquitecturagaiaestá no bom caminho, o lote de terreno ainda é grandinho!
    as escadas é que podia ter feito de outra maneira mas são gostos(vai acabar por se cansar delas).
    Sou de Vila Nova de Gaia, se precisar de opiniões ou algo só dizer somos de perto. Como é aqui do forum é tudo boa gente.
    o lote tem 1000m2
    as escadas sao um toque pessoal. acho que é uma característica particular da casa. pensei assim a escadaria para dar aceso rapido nos dois sentidos da casa/terreno.
    opinioes sao sempre vem vindas!!
0.0291 seg. NEW
