Colocado por: miguel.fernandesBem, enquanto a construção está parada e para não deixar o tópico morrer, há que semear qualquer coisita.
Alfaces e Morangos
//=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.g.height&&c<=b.g.width)}a&&(b.a.push(e),b.c[e]=!0)}p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});function r(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.i&&(e="&rd="+encodeURIComponent(JSON.stringify(t())),131072>=a.length+e.length&&(a+=e),d=!0);u=a;if(d){c=b.h;b=b.j;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(v){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}}function t(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("data-pagespeed-url-hash");e&&(!(e in b)&&0=b[e].o&&a.height>=b[e].m)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b}var u="";h("pagespeed.CriticalImages.getBeaconData",function(){return u});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/47258/7/construcao-de-casota-para-arrumacao/','RLUqK6vQLm',true,false,'b63rH0H_yZM'); //]]>
Cebola, Alho Francês e Feijão Verde
Batatas
Quanto ao material, tenho aqui blocos para uns 3 ou 4 fiadas. Ver se este sábado faço alguma coisa que estou de folga..
Tenho também 3 laranjeiras, 1 clementina, 2 pessegueiros, 1 diospireiro, 1 nogueira, 1 loureiro, 1 ameixoeira e 22 videiras.
O terreno é pequeno, cerca de 400 m2 em forma de rectângulo, mas acho que consegui distribuir bem as coisas.
Quero também fazer uns canteiros para por umas flores e um jardim à maneira.
Já agora, só para terem uma ideia do antes e do durante:
Onde hoje assenta a minha edificação, um dia esteve esta "coisa" também conhecida por ninho de cobras e ratos.
Colocado por: tozepalmaAssumo que não percebi muito do assunto, porque bloco em vez de tijolo? Qual a vantagem? O tijolo seria mais barato, certo?
Colocado por: GMCQEssa ultima foto faz lembrar o que estava antes no lugar do meu canil.... mas acho que essa anterior ''(des)construçao'' bate em alguns pontos a minha, a ver se consigo achar uma foto do antes... :)
É um orgulho ver que conseguimos fazer "qualquer coisa" :)
Depois mostre o seu antes e depois.
Colocado por: O.MartinsMiguel, isso é terreno agrícola, ou é o terreno da sua moradia?
Tem que ganhar coragem para acabar isso...
Foco! E boa sorte.
Colocado por: O.MartinsMas está no seu terreno, essa construção?
Agora entendo porque está a levar tanto tempo.. Só lá vai de x em quando.
Tinha ideia que era ilegal qualquer construção maciça nesses terrenos...
Se vai ter longos períodos de ausência, atenção à janela. Reforce bem isso.
Sim, está na minha parte.
Não tem a ver com o ser de tijolo ou de madeira, mas sim com as áreas cobertas.
Costumo ir lá frequentemente mas tenho trabalhado todos os fds pelo que tem sido impossível.
No entanto, a segurança foi pensada. Arranjei duas destas numa obra aqui perto. Podiam ser mais bonitas mas como foram de borla...
Colocado por: marco1desde que não caia, vai ficar bem.
