Colocado por: eu
Essa medida não é bem quase igual: o diâmetro exterior do pneu é menor...
Se quiser determinar medidas equivalentes, use este simulador:https://tiresize.com/tyre-size-calculator/
Colocado por: civismo
Realmente ha mais diferenças entre pneus
//=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/44145/2/pneus-seguranca-e-mais-durabilidade-quais-escolher/','ru-31rbADx',true,false,'Bw14rjHmMBM'); //]]>
Colocado por: Rui A. B.Qualidade excelente: Continental ContiSportContact 5Era os pneus que metia, fazia poucos km
Colocado por: pjfEra os pneus que metia, fazia poucos km
Colocado por: civismoTenho uma questão de indole legal:
A minha carrinha mercedes W210 usa pneus 215/55 R16 , os quais são carissimos.
No meu caso, uso os michelin Primacy, e por pouco mais de metade do preço existe uma medida quase igual: 205/55 R16
A diferença sao +/- 130€ para o 215/55 conta +/- 80€ para o 205/55
A questão é : posso usar na minha carrinha 205/55 R16, apesar de nao virem no livrete ?
Perguntei a um inspector que me disse que na inspecção não tem problema, pois esta dentro da tolerancia, que o unico problema que poderei ter é com a Policia, se for mandado parar podem multar-me ou até apreender a viatura e tal ...
Que me dizem ?
Colocado por: ANdieselO maximo 30 ,35 mil km tenho de trocar os 4 , Penso que o problema de ter trocar de pneus todos os anos é que o carro é muito pesado ,vazio passa os 2500 kg ,viagens de 2000 km sempre a botar calor ,agora meti um pneu a metade do preço vou ver os km que consigo fazer.
No meu SUV tenho estes e duraram quase 60.000km (frente), os de trás ainda se mantém. Considero uma boa durabilidade, face à boa segurança que transmitem.
Colocado por: pjfO maximo 30 ,35 mil km tenho de trocar os 4 , Penso que o problema de ter trocar de pneus todos os anos é que o carro é muito pesado ,vazio passa os 2500 kg ,viagens de 2000 km sempre a botar calor ,agora meti um pneu a metade do preço vou ver os km que consigo fazer.2500 kg de peso ? Isso é um blindado ????
Colocado por: rafaelisidoro2500 kg de peso ? Isso é um blindado ????Por acaso fui agora retificar pesa 2400 kg!
Colocado por: callinasFaz sentido estás medidas serem equivalentes?
Colocado por: eupor acaso ha uma diferença bem grande na largura do pneu ... pode nem caber num carro , o que fica igual e a medida da volta do pneu faz os mesmos km , sao iguais ...
Se os pneus usam a mesma medida de jante e têm o mesmo diâmetro exterior, onde está a dúvida?
Colocado por: Anonimo16062021por acaso dependendo da largura do pneu o 65 até pode ser muito mais baixo que o 55 , uma vez que estes valores são % em relação à largura ...
A diferença que faz a que um é de perfil baixo (55) e outro perfil alto (65)
Colocado por: rafaelisidoropor acaso dependendo da largura do pneu o 65 até pode ser muito mais baixo que o 55 , uma vez que estes valores são % em relação à largura ...
Colocado por: Anonimo16062021lol o que é que achou disso ?
Essa é boa Rafa
Colocado por: JoaoPinapois mas não é , é a percentagem sobre o primeiro valor que é a largura ...
Eu pensava que isso fosse a altura em mm
Colocado por: Anonimo16062021pois tinha percebido isso ...OK
Uma tontaria
Colocado por: Anonimo16062021não , pode ate ser ao contrario ... Tudo depende da largura , é a largura que determina com a % o tamanho do perfil .
Quanto menor for esse número, % mais baixo será o perfil do pneu..ponto
