Colocado por: Joao Dias...
//=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.g.height&&c<=b.g.width)}a&&(b.a.push(e),b.c[e]=!0)}p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});function r(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.i&&(e="&rd="+encodeURIComponent(JSON.stringify(t())),131072>=a.length+e.length&&(a+=e),d=!0);u=a;if(d){c=b.h;b=b.j;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(v){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}}function t(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("data-pagespeed-url-hash");e&&(!(e in b)&&0=b[e].o&&a.height>=b[e].m)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b}var u="";h("pagespeed.CriticalImages.getBeaconData",function(){return u});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/43892/75/fino-oficio-como-prometido/','eMkCkvev5V',true,false,'hn6jLN0KGzY'); //]]>
Colocado por: Falancio
João, este chão é exactamente como o chão que tenho na minha casa e se mostou disponivel a ajudar. na minha casa tenho a divisão da esquerda, o hall e o quarto para fazer afagamento. Para que valores, necessitava?
Pode responder por mensagem privada se se sentir mais à vontade.
Colocado por: SkinkxEu devo ser o "estraga-coisas" cá do sítio, mas acho que só ia gostar desse chão num chalé de montanha, estilo casa de férias com decoração rústica...
Ó João, não me leve a mal, juro que não é só para pôr o defeito, mas gosto mesmo do soalho longilíneo, nem sequer sou adepto de parquets ou de tacos pequenos... :-)
Uma coisa é certa, aquilo que parece num computador pode parecer outra coisa completamente diferente vista ao vivo...
Colocado por: CMartin
Skinkx,
Mas que disparate de coisa de se dizer!
O João Dias restaura os soalhos de todos e faz o que o DO lhe pede.
Nada tem a ver com o que o DO tem na sua casa ou quer colocar na sua casa, isso é ao gosto do DO.
No màximo, o João Dias pode dar umas ideias..Mas é sempre ao gosto do DO.
Ou acha que o João Dias deveria pudicamente armar-se em esquisito e recusar os soalhos que não são ao gosto dele, ou, melhor, ao gosto do Skinkx ?
Isto vê-se com cada uma. Mais valia o Skinkx não ter dado contribuição nenhuma, desculpe là.
De certeza que concorda comigo se pensar um pouco no assunto.
Cumprimentos.
Skinkx,
Cumprimentos.
Boas C,
Não querendo fazer de advogado do diabo, não encontrei malicia no comentário do Skinkx. É uma das pessoas que tal como a C tem acompanhado o tópico com alguma atenção e gosta de opinar.
Não gosta não gosta, não levo nada a mal. Cada um tem os seus gostos e preferências.
Independentemente, pelo amor da Santa não se aborreçam pois para isso já chega e sobra o trabalho que vou começar na Quinta-Feira que mais não é do que a maneira de uma qualquer entidade divina dizer "Vá, agora é que eu quero ver"...
Colocado por: GMCQ
Isso para ti não é nada. Tu gostas de um bom desafio!
Colocado por: Joao DiasPartilho aqui convosco uma das artes que mais admiro.
Marquetaria de Hakone - Japão.
https://youtu.be/TxvOMHoLRBY
O português pode ser uma língua traiçoeira, mas aqui nem me parece que tenha sido o caso, bastava ler a discussão com calma, perceber como surgiu aquele soalho em específico e perceber o contexto da afirmação.
O João colocou aí fotos dum soalho supostamente topo de gama e singular, que nem sequer está no portfólio dele, tendo-se limitado a colocar links do fabricante. Onde todos ficaram muito satisfeitos com o material, eu apenas expressei uma opinião contrária, porque sinceramente até acho mais piada a alguns dos restauros que o João já aqui colocou antes. A minha opinião pode ser dissonante, mas terá que ter paciência e conviver com ela, que tenho direito a ter uma opinião.
E sobre os trabalhos do João, comentar um gosto pessoal em relação ao trabalho não é colocar defeito. Se o João apresentar uma madeira qualquer lacada e eu lhe disser que prefiro verniz é apenas uma opinião pessoal, não é meter defeitos na lacagem. E quando digo isto digo o que sinto e muitas vezes o João explica o porquê de ser assim e não de ser assado e só por ter feito esse comentário e ter tido resposta já fiquei a saber um bocadinho mais do que sabia se não tivesse comentado.
Resumindo e concluindo, você está-me a dar um puxão de orelhas por eu ter dito ao João que não gosto muito dum material que ele nem sequer aplicou e que nem sequer faz parte do portfólio dele, mas que tão simplesmente está, como tantos outros, disponível na web para ser apreciado e comentado. Mal estaria o mundo no dia em que não puder colocar defeitos num material, seja ele de que tipo for.
"Isto vê-se com cada uma. Mas que disparate de coisa de se dizer! De certeza que concorda comigo se pensar um pouco no assunto."
Cumprimentos.
Talvez Skinkx.
Como também ainda me custa a engolir a história de António Abrantes e a Empatias, por quem eu tinha grande admiração, se calhar o Skinkx ficou marcado na minha memória como a má língua ;o) (estou a brincar....).
:o)
Cumprimentos.
