Colocado por: riscosSe é viga de equilíbrio, o diagrama de momentos não é parabólico, não tem cargas aplicadas ao longo do vão,
Colocado por: zedasilvaProposta para ventilação do desvão sanitário.
Opinem!
//=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.g.height&&c<=b.g.width)}a&&(b.a.push(e),b.c[e]=!0)}p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});function r(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.i&&(e="&rd="+encodeURIComponent(JSON.stringify(t())),131072>=a.length+e.length&&(a+=e),d=!0);u=a;if(d){c=b.h;b=b.j;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(v){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}}function t(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("data-pagespeed-url-hash");e&&(!(e in b)&&0=b[e].o&&a.height>=b[e].m)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b}var u="";h("pagespeed.CriticalImages.getBeaconData",function(){return u});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/45775/20/diario-de-uma-aventura-construcao-de-moradia/','eMkCkvev5V',true,false,'mA613IEHTkQ'); //]]>
Colocado por: SkinkxOnde tem uma "esquadria" a NE, era fazer exactamente a mesma coisa, mas a "SW". Sai pela viga, na horizontal, e ascende na vertical até à atmosfera.
Colocado por: SkinkxSabe o que é um "L"? :-)
Colocado por: SkinkxPara mim, o ideal é uma secção que faça este trajecto, sem ferir a viga, se possível. O caminho mais à esquerda deveria correr por fora da viga, mas a sua imagem não tinha mais espaço.
Colocado por: VXMCE depois o respiro ficaria como se de um candeeiro de jardim se tratasse?
Pessoalemnte não sei se me agrada.
Nesse caso está a fazer a insuflação e extração abaixo do teto, isso não cria uma corrente de ar mesmo junto ao teto o que implica que os condensados vão-se acumular lá na mesma
Fica no chão, não precisa de subir. E o ideal é ser em alvenaria, com dimensão adequada, e não um "tubito" DN32.
Colocado por: VXMC
Skinkx e tem alguma imagem que nos possa elucidar? Assim a primeira vista pela sua descrição não me agrada. Para além de que corre o risco de entrar humidade ou água da chuva por lá. Posso até nem estar a ver bem que aconselha.
Colocado por: riscosque coisa mais feia...
