    Outras colunas com design original, para quem tiver paciencia :
    http://www.avforums.com/forums/attachments/speakers/263600d1316258300-b-w-emphasis-speakers-blueroomcoll-011.jpg
    http://media.bestofmicro.com/Large-horn-speakers-blow,C-Q-254474-13.jpg
    http://www.avforums.com/forums/attachments/speakers/261037d1315047883-b-w-emphasis-speakers-babies-002.jpg
    http://www.hometheater.com/images/b&w%20three.jpg?1282071828
    http://files.coloribus.com/files/adsarchive/part_1579/15799305/file/original-parts-speakers-600-93032.jpg
    http://www.blessthisstuff.com/imagens/stuff/transparent-speaker-people-people.jpg
    http://www.tuvie.com/wp-content/uploads/utzon-sydney-opera-house-speaker1.jpg
    http://www.newlaunches.com/wp-content/uploads/2013/01/Pod_speakers_1.jpg
    http://www.newlaunches.com/wp-content/uploads/2013/01/Pod_speakers_2.jpg
    http://www.newlaunches.com/wp-content/uploads/2013/01/Pod_speakers_3.jpg
    http://www.newlaunches.com/wp-content/uploads/2013/01/Pod_speakers_4.jpg
    http://www.newlaunches.com/wp-content/uploads/2013/01/Pod_speakers_5.jpg
    http://www.newlaunches.com/wp-content/uploads/2013/01/Pod_speakers_8.jpg
    http://www.newlaunches.com/wp-content/uploads/2013/01/egg_speaker.jpg
    http://www.e-potpourri.com/wp-content/uploads/2008/08/davone-rithm-audiophile-designer-speaker.jpg
    http://walyou.com/img/Headless-Dog-Speakers.jpg
    http://www.blogcdn.com/www.engadget.com/media/2008/05/20080505-symbioalpha.jpg
    cdn.homedit.com/wp-content/uploads/2010/06/061710_speakerrrrr2.jpg
    http://www.geeky-gadgets.com/wp-content/uploads/2010/01/teac-horn-design-speakers.jpg
    http://www.plunderguide.com/wp-content/uploads/2010/04/Voxativ-Ampeggio-Speakers-3.jpg
    http://homeklondike.com/wp-content/uploads/2011/02/1-klang-ultrasonic-speakers-design-by-adam-moller.jpg
    http://www.drhifi.net.au/Used%20Equipment/B&W/Nautilus%20800/800.jpg
    E para acabar uma aparelhagem bonita da Philips
  2.  # 62
    Boas!
    Esta não é de alta fidelidade, mas é parecido, é audiovisual !
    Estou com a seguinte situação pratica:
    Tenho um pc com uma board INTEL Media Series, a qual tem neste momento
    >Saida VGA - A qual tem um ecran de 22" Full HD (1920x1080)
    >Saida HDMI - A qual tem um Ecran 42" Full HD (1920x1080), - ligado com um cabo HDMI de 5 Metros
    >Saida DVI (A qual tem neste momento um adaptador DVI para HDMI) A qual tem um Ecran 42" Full HD (1920x1080), - ligado com um cabo HDMI de 30 Metros
    Na pratica tudo trabalha bem, mas tenho alguns problemas:
    1) Não consigo ter 3 ecrans ao mesmo tempo, pois a board intel só permite 2 de cada vez
    2) Se tiver os ecrans desligados quando arranco o pc, então não vão aparecer na listagem de clonagem dos monitores. E se ja estiver seleccionado o modo clone, faz reset e volta a single.
    3) O cabo HDMI de 30 metros é muito grosso e pouco flexivel, e ameaça partir.se junto à ficha
    Tentei 2 situações, ambas falharam:
    Cabo Splitter Konig HDMI Macho 2x HDMI Fêmea Preto
    Não funcionou de forma alguma, e perdi ainda bastante tempo com isto.
    Nunca consegui ter saida nos dois ecrans ao mesmo tempo .
    Para alem de que mete ruido na imagem (fica cheio de pixeis verdes, cor de rosa)
    Cebolas
    Depois tentei
    União HDMI FEMEA-FEMEA
    Para tentar resolver o problema referido no ponto 3, ou seja, acrecentando um cabo de 1 metro ao cabo de 30 metros, para ficar mais flexivel. Mais uma vez mete ruido na imagem (fica cheio de pixeis verdes, cor de rosa)
    Cebolas
    Estou inclinado a experimentar algo tipo isto:
    Splitter HDMI 2 Portas Aten VS182
    http://www.sonigate.com/pt/product/show_details/60414/Splitter-HDMI-2-Portas-Aten-VS182
    Cebolas
    o que acham ?
  3.  # 63
    Isso não é para ter imagem nos dois ao mesmo tempo.
    Nem me parece que seja fácil arranjar algo que faça isso.
    Só mesmo material que se usa nas lojas para ter as TV's todas ligadas à mesma fonte!!
  4.  # 64
    Colocado por: system32Isso não é para ter imagem nos dois ao mesmo tempo. --- Estas a falar do que ?
    Supostamente o da aten que ali meti atras faz isso ... e este tambem , com 4 saidas :
    http://www.sonigate.com/pt/product/show_details/2724/Splitter-HDMI-4-Portas-Aten-ATVS184
  5.  # 65
    É giro usar o telemovel como leitor de MP3, mas há casos em que as vezes não é prático.
    Prefiro um aparelho dedicado para o efeito.
    Na realidade até preciso de mais do que um, pois :
    >Um para oferecer a minha Mãe, para as musicas dela
    >Um para o meu carro
    >Um para o carro da namorada
    >Um para a aparelhagem lá de casa.
    Mas vamos a um de cada vez. Vou começar pela minha mãe, até porque anda a pedir-me ha
    algum tempo.
    O contexo: São duas divisões distintas, uma com uma aparelhagem, outra com um Radio no
    qual vou meter entrada AUX.
    Para alem disso costuma andar em transportes publicos, por isso faz todo o sentido que
    seja um aparelho que possa funcionar enquanto audio portatil.
    Por isso pensei num leitor de MP3, e hoje em dia são quase todos MP4, mas a mim
    chegava-me se fosse so Mp3.
    No entanto é interessante o facto de o ecran dos MP4 ser maior, e possibilitar uma maior facilidade a encontrar as pastas / faixas.
    Quanto aos Ipods, Creative´s, Sony´s, exclui logo pois usam softwares proprios e a maioria nem dão para cartões exteriores.
    O ideal era algo que levasse muitos GB´s e fosse facil de trabalhar.
    Por isso surgiu a hipotese do cowon com disco rigido : http://www.cowonglobal.com/product_wide/product_mp3_main.php
    Ou então genéricos, tipo Photobank dos que levam um disco sata de 2.5" , como estes
    http://www.esaleschina.com/mp4-picture-bank-sata-2-5-inch-hard-disk-enclosure-667.htm
    Os de disco rigido têm a grande vantagem da capacidade, mas em termos de fragilidade e Bateria são bem piores...
    Após pesquisar um bocado, estou inclinado para a Memup, de 2.4" ou 3" Touch.
    Penso que é o que faz mais sentido para este caso, é facil mudar os cartões micro SD ...
    Fica a duvida se isto aceitará cartões de 16 ou 32 GB, uma vez que nas especicações apenas referem que suporta cartões de 8GB
    E para uma mãe parece uma boa opção: Aparelho só para isto, intuitivo, etc.
    Ja alguem aqui experimentou estes aparelhos da Memup ?
    Eis os da minha duvida neste momento :
    MEMUP M24HD
    http://www.memup.pt/M24HD-O-tudo-em-um-da-multimedia_a146.html
    http://www.fnac.pt/Memup-MP4-M24-FM-4GB-Leitor-MP3-MP3-Audio-Video/a364286
    OU OU
    MEMUP Komet
    http://www.memup.pt/KOMET-Entre-num-novo-mundo-de-tecnologia-_a172.html
    http://www.fnac.pt/Memup-MP4-Komet-8GB-3-Leitor-MP3-MP3-Audio-Video/a600076
    Para o carro ainda não sei ... já pensei num GPS que ao mesmo tempo fosse bom leitor de MP3 .... ha algum com disco rigido de 2.5" ?
      FD
    • 4 abril 2013
     # 66
    O interface desses leitores MP3 mais baratos costuma ser... HORRÍVEL.
    Aconselho Sansa ou Sony.
  6.  # 67
    Colocado por: FDO interface desses leitores MP3 mais baratos costuma ser... HORRÍVEL.
    O interface grafico ou a qualidade de som em si ?
    O memup Komet tem 3" Touch, por isso é capaz de ser facil de chegar rapido onde se quer ..
    Pelos vistos o mais bacano da Sansa é o Fuze, que acaba por ter specs quase iguais ao Memup M24HD ... http://www.sandisk.com/products/music-video-players/fuze-plus/
    EDIT: Review interessante ao Fuze: http://www.youtube.com/watch?v=m3pnEd1njxc
      FD
    • 4 abril 2013
     # 68
    Colocado por: civismoO interface grafico ou a qualidade de som em si ?
    Mesmo o som, não acho grande coisa. Mas a interface é de fugir... pelo menos num que tenho cá em casa.
  7.  # 69
    Colocado por: FD
    Esse que tens é da memup ? E é dos mais pequenos, ou é destes de 2.4 ~3 " ?
    Estava muito inclinado a experimentar o Touch de 3" da Memup...
    Bem visto custa quase o mesmo que um tablet android ... é só por dizer que deve ser mais rapido a iniciar ...
      FD
    • 4 abril 2013
     # 70
    Colocado por: civismoEsse que tens é da memup ?
    Nem sei, acho que sim.
    É esta coisa: http://www.memup.pt/K-SLIM-LS-Leitor-MP4-Ultra-fino-Ultra-Simples_a97.html
    Agora se é Memup ou outra marca qualquer não sei, isso é tudo OEM remarcado...
  8.  # 71
    Pois, tambem já experimentei esses com ecran de 1.8" e realmente não são grande coisa de interface ... os memup que ali coloquei são de 2.4" e 3" (touch).
    Se calhar mais vale é comprar mesmo um Tablet, o qual dá para sacar o player que mais gostar , e acaba por não ser tão limitado quanto um MP4 ...
    Uma duvida: Alguns tablet têm USB OTG .. Será que dá para ligar a um disco externo ? :)
      FD
    • 4 abril 2013
     # 72
    Colocado por: civismoe calhar mais vale é comprar mesmo um Tablet
    É o que eu costumo fazer, se calhar é melhor mais isto, e mais isto e mais isto.
    Há tempos comprei um leitor de Blu Ray porque o leitor de DVD que tinha pifou.
    Fui nessa do "é melhor ter isto" e "mais isto" e "mais aquilo" e, num ano, um leitor com acesso à net, browser, Youtube e mais uma data de funcionalidades foi unicamente usado para... ler DVDs.
  9.  # 73
    Lol, eu compreendo que as vezes muita coisa é adiada enquanto se espera pela "perfição", e que quando a "perfição" finalmente chega, raramente tiramos partido pleno dela :)
  10.  # 74
    Cada vez gosto mais de radios tipo boombox. Vou começar a minha colecção :)
    Para ja um video com a historia das Boomboxes [URL]http://www.youtube.com/watch?v=e84hf5aUmNA[/URL]
    Exemplos:
  11.  # 75
    E este?
  12.  # 76
    Colocado por: pedromdfE este?
    Vi ontem uma da philips quase igual a essa, numa loja remar :) tinham acabao de vender, estava reservada por 50E
  13.  # 77
    E os míticos Marantz!
  14.  # 78
    Fica bonito iluminado com o azul característico.
    Concordam com este comentário: civismo
  15.  # 79
    Também tenho este pedaço da história da alta fidelidade a válvulas.
  16.  # 80
    Esta peça também faz história desde 1926!
0.0321 seg. NEW
