    depois... trabalho finalizado já de noite
  2.  # 282
    Colocado por: carlosfbmanuel//=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/22502/5/recuperacao-de-farois/','B6nXayd9mu',true,false,'V-qPWNeA28o'); //]]>antes
    antes
    antes
    antes
    durante
    durante
    depois
    depois
    resultado final
    Ora então em dezembro resolvi dar como prenda de natal uma manutenção grátis a todos os clientes que passaram por cá..esta vai vir para fazer uma manutenção...a ver como está, umas opticas que estão diariamente ao sol, sem qualquer tipo de cuidado portanto após quase 3 anos...vamos ver como estão...
  3.  # 283
    Colocado por: carlosfbmanueldiga-me a zona que poderei indicar alguém de confiança que lhe faça o trabalho.
    Aveiro. Se puder indicar alguém agradeço. Não é que os faróis estejam e fracas condições (se assim fosse já teria comprado novos. Só é pena que tenha de
    comprar a ótica completa se algum dia pensar nisso), mas se estivessem mesmo no ponto ficaria mais satisfeito.
  4.  # 284
    não tem fotos dos faróis??
  5.  # 285
    Não. É claro que posso tirar, mas creio que não adiantará muito.
    Como já tinha referido, os faróis não estão amarelados por causa do sol ou do calor das lâmpadas. O que eles têm é marcas das areias que ali batem. Significa que,
    apesar de já terem sido polidos, têm pequeninos sulcos. Se calhar nem é possível fazer melhor do que o que já foi feito...
  6.  # 286
    pode ser que tenha sido só retirado a película que têm de origem...mas só vendo mesmo...
    Estes riscos eram fundos, cabia lá uma unha....
    depois...deu muito trabalho mas saíram....mas cada caso é um caso
  7.  # 287
    ácido e um golpe fundo...
    aqui ainda se nota o golpe
    aqui o resultado final onde o golpe nem é perceptível
  8.  # 288
    um carro com uns belos anos e onde andaram a colocar lampadas de 100w porque não viam bem, o que leva a queimarem os espelhados, e aí nada a fazer...
  9.  # 289
    Carlosfbmanuel, sempre conhece alguém na zona de Aveiro que possa fazer esse trabalho?
  10.  # 290
    Parabéns pelos trabalhos apresentados Carlosfbmanuel, muito bom.
    Colocado por: sousa tavaresCarlosfbmanuel, sempre conhece alguém na zona de Aveiro que possa fazer esse trabalho?
    Não conhece nenhuma oficina que tenha pintura aí na zona?Acho que não deve ser um serviço muito caro.
  11.  # 291
    Mas isso já eu fiz. Não fiquei contente com o trabalho. Penso que poderia e deveria ficar melhor. Não afeta a qualidade da luz emitida, mas esteticamente não
    está como gosto.
  12.  # 292
    Em Aveiro não conheço ninguém e já perguntei a uns colegas e ninguém sabe de ninguém de confiança.
    Estas pessoas agradeceram este comentário: sousa tavares
  13.  # 293
    Colocado por: sousa tavaresMas isso já eu fiz. Não fiquei contente com o trabalho. Penso que poderia e deveria ficar melhor. Não afeta a qualidade da luz emitida, mas esteticamente não
    está como gosto.
    só vendo e depois eu já aqui tive um farol de uma vespa que nem polido por dentro e por fora resultou...conclusão o cliente não pagou nada e ainda fiz 100km para lhe entregar o farol....o que eu ganhei com isto foi...confiança nos trabalhos...
    Concordam com este comentário: sousa tavares
  14.  # 294
    Parabéns pelos seus trabalhos
    Estas pessoas agradeceram este comentário: carlosfbmanuel
  15.  # 295
    mais um daqueles....so com 16 anos....antes
  16.  # 296
    Depois...mas ainda com 16 anos :)
  17.  # 297
    ora mais um em muito mau estado:
  18.  # 298
  19.  # 299
    depois de algumas horas:
  20.  # 300
    Os faróis melhoram bastante, esfregados com pasta de dentes ou cif.
0.0300 seg. NEW
