    Mami House is a "mini bunker" built for a couple on a very tight budget
    Faced with the difficult task of delivering a family house for less than €100,000, Portuguese architect José Carlos Nunes de Oliveira designed this cuboidal concrete property.
    https://www.dezeen.com/2017/05/09/mami-house-noarq-low-budget-concrete-home-portugal-mini-bunker-jose-carlos-nunes-de-oliveira-noarq/
  2.  # 142
    Colocado por: branco.valterMami House is a "mini bunker" built for a couple on a very tight budget
    Faced with the difficult task of delivering a family house for less than€100,000, Portuguese architect José Carlos Nunes de Oliveira designed this cuboidal concrete property.
    //=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.g.height&&c<=b.g.width)}a&&(b.a.push(e),b.c[e]=!0)}p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});function r(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.i&&(e="&rd="+encodeURIComponent(JSON.stringify(t())),131072>=a.length+e.length&&(a+=e),d=!0);u=a;if(d){c=b.h;b=b.j;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(v){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}}function t(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("data-pagespeed-url-hash");e&&(!(e in b)&&0=b[e].o&&a.height>=b[e].m)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b}var u="";h("pagespeed.CriticalImages.getBeaconData",function(){return u});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/4299/106/construir-moradia-com-100000-e-possivel/','RLUqK6vQLm',true,false,'cgR4bm_bC_c'); //]]>
    Esse arquitecto e da Trofa. Conheco-o pessoalmente. Trabalhou com o Siza Vieira.
    Admira-me que tenha feito um projecto tão contido.
    Mas tem bons exemplos de construções na Trofa.
  3.  # 143
    Colocado por: emadAdmira-me que tenha feito um projecto tão contido
    porquê??
  4.  # 144
    Fez por 100K ? Então pediu ao arquitecto casa por 50K e acabou nos 100K.😂😂
    Desculpe Marco mas não me contive .
    Concordam com este comentário: FilipeOliveira78, JErso
  5.  # 145
    Colocado por: marco1
    porquê??
    Não quero dizer que um arquitecto não faça de tudo. Estou habituado a ver outro tipo de trabalhos.
    Mas percebo perfeitamente.
    Concordam com este comentário: HAL_9000
  6.  # 146
    Casa de 100 mil é casa de pobre... tem que ser dos 500 para cima!
  7.  # 147
    Colocado por: tnjpCasa de 100 mil é casa de pobre... tem que ser dos 500 para cima!
    e pode ser de outra forma??
  8.  # 148
    Então não pode? Qual o problema de fazer uma casa de 100 mil, sendo rico ou pobre?
    É que por vezes vejo algo implícito em alguns comentários, que as casas só têm valor de um certo valor para cima...
  9.  # 149
    Tenho sérias duvidas que essa casa tenha ficado por 100k.
    Concordam com este comentário: emad, nunogouveia, two-rok
      GMCQ
    • 13 maio 2017 editado
     # 150
    Colocado por: tnjp
    Para mim aquela casa chegava e sobrava, neste momento abdico um pouco mais do espaço interior para ganhar em espaço exterior, que é o que me faz mais falta!
  10.  # 151
    Colocado por: alexpTenho sérias duvidas que essa casa tenha ficado por 100k.
    Concordam com este comentário:emad
    Nao percebo porque, a casa é bem simples por isso acredito que tenha ficado pelos 100k...
  11.  # 152
    Quando estiver com o arquitecto José Carlos que fez essa casa, vou questionar como o conseguiu fazer e em que condicionantes o conseguiu fazer que não conseguimos ver.
    Estas pessoas agradeceram este comentário: JErso
  12.  # 153
    Colocado por: DR1982
    Madeiras, serie de alumínio minimalista ...
  13.  # 154
    Colocado por: Anonimo06082021e as madeiras....os painéis poderão ser em aglomerado folheado
    as escadas parecem-me madeira de Eucalipto
    Para mim chegava e sobrava
    Concordam com este comentário: Anonimo06082021, JErso
  14.  # 155
    Colocado por: Anonimo06082021essa casa não dá/serve para o pessoal daqui deste fórum.....não parece ter tijoleiras imitadoras nem soalhos AC não sei das quantas....
    Tem razão. Para mim dava e muito bem. Mas mostrei à minha esposa e ela disse. Um bunker? Madeira faia? Não gosto.
    Depois isto só pode dar em divórcio.
    Já cantava o Rui Veloso, se não ouvires a mesma musica, a coisa não dá.
  15.  # 156
    o descofra e tá pronto....tem muitas vantagens.
    não tem revestimentos extra e respectiva mão de obra sem contar com a logística necessária.
    não gasta tintas etc etc....
    E fica bonito!
    O chão não levanta problemas? Tenho visto alguns em espaços comerciais que acabam por abrir vendas. Provavelmente devido a má aplicação...
  16.  # 157
    A propria estrutura da casa é simples, 4 paredes sem cantos e recantos, sem varandas nem alpendres, o descofra e esta pronto como o james disse e bem, o chao, etc
    A simplicidade de construção também influencia e muito o preço final...
    Concordam com este comentário: Anonimo06082021, jorgferr, FilipeOliveira78
  17.  # 158
    mas isso até pode dar originalidade ao ambiente....muitas vezes criam-se fendas de propósito que podem ainda ser trabalhadas
    tudo depende.
    mas quando fissuram é porque algo não foi bem feito.
    Os exemplos que vi ficaram bem feios, para o meu gosto. Mas são espaços comerciais com tráfego intenso, talvez não seja a melhor solução.
    Esta questão do chão é o que mais dúvidas me levanta...
  18.  # 159
    Colocado por: alexp
    Para não falar em chãos de madeira, aparelhagem electrica xpto, os arranjos exteriores e muros, a mão de obra necessaria para executar as paredes em betão com o cuidado necessario para ficarem à vista, o planeamento e execução dos negativos no betão para a aparelhagem eléctrica, provavelmente o chão não foi apenas afagado, execução de cave num terreno plano, ETICS ,
  19.  # 160
    Cave num terreno plano? Eu não vejo nenhuma cave...
    O chao foi apenas afagado pelo menos tem aspecto disso...
    Os negativos nos muros de betao à vista nao dao nenhum trabalho em especial, quanto aos muros propriamente ditos basta ter betao bom e quem saiba vibrar em condiçoes nada mais...
    160m2 por 100.000€ Fica a cerca de 625€/m2 nao me parece nada impossivel repito...
0.0249 seg. NEW
