Colocado por: branco.valterMami House is a "mini bunker" built for a couple on a very tight budget
Faced with the difficult task of delivering a family house for less than€100,000, Portuguese architect José Carlos Nunes de Oliveira designed this cuboidal concrete property.
//=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.g.height&&c<=b.g.width)}a&&(b.a.push(e),b.c[e]=!0)}p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});function r(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.i&&(e="&rd="+encodeURIComponent(JSON.stringify(t())),131072>=a.length+e.length&&(a+=e),d=!0);u=a;if(d){c=b.h;b=b.j;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(v){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}}function t(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("data-pagespeed-url-hash");e&&(!(e in b)&&0=b[e].o&&a.height>=b[e].m)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b}var u="";h("pagespeed.CriticalImages.getBeaconData",function(){return u});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/mod_pagespeed_beacon','https://forumdacasa.com/discussion/4299/106/construir-moradia-com-100000-e-possivel/','RLUqK6vQLm',true,false,'cgR4bm_bC_c'); //]]>
https://www.dezeen.com/2017/05/09/mami-house-noarq-low-budget-concrete-home-portugal-mini-bunker-jose-carlos-nunes-de-oliveira-noarq/
Colocado por: emadAdmira-me que tenha feito um projecto tão contido
Colocado por: marco1
porquê??
Colocado por: tnjpCasa de 100 mil é casa de pobre... tem que ser dos 500 para cima!
e pode ser de outra forma??
Colocado por: tnjp
Então não pode? Qual o problema de fazer uma casa de 100 mil, sendo rico ou pobre?
É que por vezes vejo algo implícito em alguns comentários, que as casas só têm valor de um certo valor para cima...
Colocado por: alexpTenho sérias duvidas que essa casa tenha ficado por 100k.
Colocado por: DR1982
Nao percebo porque, a casa é bem simples por isso acredito que tenha ficado pelos 100k...
Colocado por: Anonimo06082021e as madeiras....os painéis poderão ser em aglomerado folheadoPara mim chegava e sobrava
as escadas parecem-me madeira de Eucalipto
Colocado por: Anonimo06082021essa casa não dá/serve para o pessoal daqui deste fórum.....não parece ter tijoleiras imitadoras nem soalhos AC não sei das quantas....
o descofra e tá pronto....tem muitas vantagens.
não tem revestimentos extra e respectiva mão de obra sem contar com a logística necessária.
não gasta tintas etc etc....
mas isso até pode dar originalidade ao ambiente....muitas vezes criam-se fendas de propósito que podem ainda ser trabalhadas
tudo depende.
mas quando fissuram é porque algo não foi bem feito.
Colocado por: alexp
Madeiras, serie de alumínio minimalista ...
